loldongslol
Mar 06, 2013Aspirant
Netgear A6200 cannot see 5GHz Network from ASUS RT-N66U
I recently purchased an Asus RT-N66U which I'm very excited about. I also picked up a Netgear A6200 USB WiFi adapter. It's 802.11ac Dual Band compatible (says so on the box). When I set up the router...
loldongslol
I followed to instructions completely as far as I know. I could try uninstalling the software and re-installing again to make sure.
I should have mentioned, I'm on a PC so other built-in wireless cards aren't an issue.
Thanks for the reply.
