loldongslol
Mar 06, 2013Aspirant
Netgear A6200 cannot see 5GHz Network from ASUS RT-N66U
I recently purchased an Asus RT-N66U which I'm very excited about. I also picked up a Netgear A6200 USB WiFi adapter. It's 802.11ac Dual Band compatible (says so on the box). When I set up the router...
loldongslol
After a day of trial and error I got this fixed!
The adapter had a cryptic setting in the device properties which preferred 802.11a. Disabled that and it's working perfectly.
Thanks for the help.
