loldongslol
Mar 06, 2013Aspirant
Netgear A6200 cannot see 5GHz Network from ASUS RT-N66U
I recently purchased an Asus RT-N66U which I'm very excited about. I also picked up a Netgear A6200 USB WiFi adapter. It's 802.11ac Dual Band compatible (says so on the box). When I set up the router...
bobbyrulez
Mar 13, 2013Aspirant
Can you please be more specific regarding what you disable and where to find it. I also have same devices and same trouble connecting to 5Ghz network only. Thanks!
