jithins
Aug 29, 2015Aspirant
Netgear A6200 Keeps disconnecting and overheating
Hi, my netgear adapter keeps over heating and disconnects, or jsut disconnects at random times, I have minimum power consumption disabled as a fix ive read, it has not helped. My computer is window...
jithins
Sep 02, 2015Aspirant
how do i check the temperature?
JamesGL
Sep 03, 2015NETGEAR Employee Retired
Hi jithins,
We can provide exact temperature for the unit but if you think it is not the normal temperature like it was before then it might be a hardware issue.
JamesGL
Community Team
- jithinsSep 03, 2015Aspirant
Ye its abnormally hot... this has been the case for 3/5 adapters (netgear a6200) i have at home... i have to put fan near it to vent the hot air
- JamesGLSep 04, 2015NETGEAR Employee Retired
If you have a USB port in the front panel of your computer, please try to connect it and check if the same temperature. If it still has the same temperature and also you have tried connecting it on different computers, please check the warranty of your device. NETGEAR has 90 days phone support and 1 year hardware warranty from the date of purchase. You may need to contact support team for hardware issue.
JamesGL
Community Team
