creeper277
Jan 04, 2015Follower
Netgear A6210 internet drops
So, I just got the Netgear A6210 network adapter for Christmas because I was having problems with my old one and it works great but the only problem is I'm getting internet drops randomly for like a ...
darrylpluto
Jul 26, 2016Aspirant
Hello, I am having a similar issue where whenever I start to play online video games my connection will randomly drop out for a second or two then immediately reconnect, although this doesn't sound like a big issue it's very annoying when you're in the middle of an intense match and you're kicked from the game server for losing connection. I have tried everything sugguested in this thread and I still have no proper fix. Please, someone at Netgear, help us.
Edit: I'm running Windows 7 ultimate if this matters. It's odd because for the last six months I've had this adapter it's worked like a dream, it's only started doing this a few days ago
JamesGL
Jul 28, 2016NETGEAR Employee Retired
Hi darrylpluto,
Try to uninstall the driver with genie and reinstall using the standalone driver.
JamesGL
Community Team
- InnvaerOct 10, 2016Aspirant
Hi!
I have the same problem as darrypluto, but im on Windows 10. I tried to uninstall the driver/genie and install the standalone driver.
Run into som problems in the prossess, like my pc didn't recognize the adapter when i was told to plug it in, but i got around it and got connection again.
However it didn't help in regards to the issue when im playing video games, i keep losing connection for 1-2 seconds, then i reconnects back. This is a big issue.
It feels like package loss or something. It was working totally fine for the first 3 months after purchase, it just started 2-3 days ago.
- On device manager it says my driver versjon is: 5.1.22.0
- Windows 10
Thanks for any help.
- JBrander7Oct 11, 2016Guide
Mate save yourself the headache, cut your losses and move on from that failed product. There is no fix. The NETGEAR staff have done absolutely nothing. I splashed out $80 on a D-LINK and it works amazingly. In comparison cheaper and more reliable.
- bigfatronDec 18, 2016Tutor
Is this issue being worked on? Mine is now intolerably unstable (been dropping out a couple of times per hour today) and if no fix is forthcoming or in the works then i'd rather just cut my losses and get my money back and buy something that actually works reliably.
