creeper277
Jan 04, 2015Follower
Netgear A6210 internet drops
So, I just got the Netgear A6210 network adapter for Christmas because I was having problems with my old one and it works great but the only problem is I'm getting internet drops randomly for like a ...
MikeBlack
Feb 06, 2015Novice
MikeBlack wrote: I have been having a similar problem where the A6210 occasionally seems to drop its connection to my Wifi, loses internet connection and says that no networks are available. A reboot fixes it. I am running Win 7 Pro 64bit on a Dell Opti-Plex 960.
Here is one possible fix I am currently trying. Go to control panel, click on "System," open up the "Device Manager." Click on "Network Adapters," right click on the "A6210" and select "Properties." Click on the "Power Management" tab.
Make sure "Allow the computer to turn off this device to save power" is unchecked.
UPDATE: The fix did NOT work
