creeper277
Jan 04, 2015Follower
Netgear A6210 internet drops
So, I just got the Netgear A6210 network adapter for Christmas because I was having problems with my old one and it works great but the only problem is I'm getting internet drops randomly for like a ...
Wyntor
Apr 11, 2015Novice
Wyntor wrote: I had the drop problem with the 6200. After installing the Firmware upgrade (1.0.0.88 ) the internet drops vanished.
This firmware upgrade fixed it only partly. While browsing the dropouts are no longer giving the website reset display but playing WoW the dropouts stopping you from changing character. I had to install my old DGN1000 to avoid this. Of course the old DGN1000 is not as good as the A6210 in the wireless department. I hope Netgear will release a better upgrade otherwise 300 dollars wasted.
