astsam
Mar 26, 2015Novice
Netgear A6210 not showing 5ghz band
Good afternoon, I recently purchased a Netgear R7000 Nighthawk to make use of the high speed 5ghz band, only to find out that my usb adapter (A6210) is unable to view it as an available network. ...
Retired_Member
Mar 27, 2015Have you tried the driver only installation and then using the typical windows control of the adapter.
Look in the adapter settings for wireless mode see if A is selected it should be. I don't have this adapter so I can't be sure what you'll find.
