astsam
Mar 26, 2015Novice
Netgear A6210 not showing 5ghz band
Good afternoon, I recently purchased a Netgear R7000 Nighthawk to make use of the high speed 5ghz band, only to find out that my usb adapter (A6210) is unable to view it as an available network. ...
xDredgex
Apr 01, 2015Novice
Have you tried forcing the 5GHz as preferred?
OS > Device Manager > Network Adapters > NETGEAR A6210 (double-click) > Advanced > Prefer 5G = Enabled?
After I did this the adapter wouldn't even bother looking for my 2.4 band, it just displayed the 5, connected.
I hope this helps.
I hope this helps.
