Ben_Binks_2012
Jul 28, 2017Aspirant
NETGEAR A6210 WiFi USB3.0 Adapter Connection Speed Still 54Mb/s Argggh!
I have installed software version 1.0.0.36 as recommended on this forum, I have set the USB Speed to 3.0 in the Advanced tab, I have disabled the NetgearUSBSwitch process from Start-up, and probably ...
- Aug 20, 2017
Hi
Sorted the issue with the USB2 port speed last night by uninstalling Genie and the drivers for the A6210 manually. Then used the standalone driver pack.
T
JamesGL wrote:Hi Ben_Binks_2012,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
hanks
JamesGL
Aug 02, 2017NETGEAR Employee Retired
Hi Ben_Binks_2012,
Uninstall the driver with Genie and try installing the standalone driver.
Ben_Binks_2012
Aug 05, 2017Aspirant
Thanks but I have already tried this numerous times. Like I said, I had everything done and working, shutdown the PC, started back up a while later, and the message came up again telling me the device can perform faster.........so I checked and sure enough 54Mb/s. Wounded haha
- JamesGLAug 09, 2017NETGEAR Employee Retired
Hi Ben_Binks_2012,
Do you have another computer? Try to install it and check if the same error.
- JamesGLAug 13, 2017NETGEAR Employee Retired
Hi Ben_Binks_2012,
- Ben_Binks_2012Aug 20, 2017Aspirant
Hi
T
hanks
