Revheat
Feb 04, 2017Initiate
NETGEAR A6210 WiFi USB3.0 Adapter not functioning correctly in usb 3.0 ports
Hello all, Ive had this NETGEAR A6210 WiFi USB3.0 Adapter for about 6 months and have had no problems until recently. Last week I was unable to connect to any wireless network (or even detect the...
- Feb 09, 2017
Hi Revheat,
Is the adapter still being detected under the device manager?
Try to uninstall and reinstall the driver.
JamesGL
Feb 09, 2017NETGEAR Employee Retired
Hi Revheat,
- JamesGLFeb 13, 2017NETGEAR Employee Retired
Hi Revheat,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- RevheatFeb 16, 2017Initiate
Sorry for the delay, I had unsubscribed from my post since I've given up on understanding this strange situation.. Ive uninstalled the device multiple times and used as many versions of the device drivers I can find..after an undeterminable amount of time the device will report no connections available while plugged into the USB 3.0 ports, though it functions normally while in a USB 2.0 port..I also make sure the USB 3.0 ports are still working properly with other devices..
I do not believe the adapter is at fault, it must be some kind of confilct in windows..
