Revheat
Feb 04, 2017Initiate
NETGEAR A6210 WiFi USB3.0 Adapter not functioning correctly in usb 3.0 ports
Hello all, Ive had this NETGEAR A6210 WiFi USB3.0 Adapter for about 6 months and have had no problems until recently. Last week I was unable to connect to any wireless network (or even detect the...
- Feb 09, 2017
Hi Revheat,
Is the adapter still being detected under the device manager?
Try to uninstall and reinstall the driver.
JamesGL
Feb 09, 2017NETGEAR Employee Retired
Hi Revheat,
JamesGL
Feb 13, 2017NETGEAR Employee Retired
Hi Revheat,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- RevheatFeb 16, 2017Initiate
Sorry for the delay, I had unsubscribed from my post since I've given up on understanding this strange situation.. Ive uninstalled the device multiple times and used as many versions of the device drivers I can find..after an undeterminable amount of time the device will report no connections available while plugged into the USB 3.0 ports, though it functions normally while in a USB 2.0 port..I also make sure the USB 3.0 ports are still working properly with other devices..
I do not believe the adapter is at fault, it must be some kind of confilct in windows..
