NeedHelpBCimDum's avatar
Jul 11, 2017
NETGEAR genie A6200 problems; Red light appears and wont go away on the adapter.
Hey there everyone!
My name is Ben and i bought a custom PC on ebay. The thing is that it was custom built and could not connect to the internet the regular way, so he sent me a D - link, unforuntally that didnt work and then sent a A6200 Netgear product, it was working fine till it started disconnecting and connecting into random (But same connection proxy servers). I did not understand that to i just Un-installed everything and re-installed it. It stopped disconnect/connecting but now the adapter light is Red and doesnt change. I have AT&T UVERSE or something like that .
P.S. This is how i installed it.
Uninstalled everything
Went to Netgear set up, downloaded the driver
Restarted my PC
Opened Netgear Genie and manually connected using WPS
Thats it ~~
Here is more info !!
---System Information---
Host Name: OWNER-PC
OS Name: Microsoft Windows 10 Pro
OS Version: 10.0.15063 N/A Build 15063
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: owner
Registered Organization:
Product ID: 00330-80000-00000-AA467
Original Install Date: 7/11/2017, 4:38:00 PM
System Boot Time: 7/11/2017, 5:28:53 PM
System Manufacturer: BIOSTAR Group
System Model: A68MD PRO
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: AMD64 Family 21 Model 48 Stepping 1 AuthenticAMD ~3700 Mhz
BIOS Version: American Megatrends Inc. 4.6.5, 12/15/2015
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
System Locale: en-us;English (United States)
Input Locale: en-us;English (United States)
Time Zone: (UTC-05:00) Eastern Time (US & Canada)
Total Physical Memory: 8,112 MB
Available Physical Memory: 6,185 MB
Virtual Memory: Max Size: 16,304 MB
Virtual Memory: Available: 13,834 MB
Virtual Memory: In Use: 2,470 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: N/A
Hotfix(s): 2 Hotfix(s) Installed.
[01]: KB4021572
[02]: KB4022725
Network Card(s): 4 NIC(s) Installed.
[01]: TAP-Windows Adapter V9
Connection Name: Ethernet 2
Status: Media disconnected
[02]: TunnelBear Adapter V9
Connection Name: Ethernet 3
Status: Hardware not present
[03]: Realtek PCIe GBE Family Controller
[04]: NETGEAR A6200 WiFi Adapter
Connection Name: Wi-Fi 2
DHCP Enabled: Yes
DHCP Server: 192.168.1.254
IP address(es)
[01]: 192.168.1.81
[02]: fe80::99fe:39f7:5f5a:7d43
[03]: 2602:306:3627:e750:e011:3d29:cce4:c94
[04]: 2602:306:3627:e750:99fe:39f7:5f5a:7d43
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: Yes
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
---System Network Information---
Windows IP Configuration
Host Name . . . . . . . . . . . . : owner-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : attlocal.net
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : B8-97-5A-CE-5D-0D
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-C4-A2-80-86
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : A2-63-91-3D-F9-5B
Wireless LAN adapter Wi-Fi 2:
Connection-specific DNS Suffix . : attlocal.net
Description . . . . . . . . . . . : NETGEAR A6200 WiFi Adapter
Physical Address. . . . . . . . . : A0-63-91-3D-F9-5B
IPv6 Address. . . . . . . . . . . : 2602:306:3627:e750:99fe:39f7:5f5a:7d43(Preferred)
Temporary IPv6 Address. . . . . . : 2602:306:3627:e750:e011:3d29:cce4:c94(Preferred)
Link-local IPv6 Address . . . . . : fe80::99fe:39f7:5f5a:7d43%25(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.81(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, July 11, 2017 5:32:12 PM
Lease Expires . . . . . . . . . . : Wednesday, July 12, 2017 5:32:12 PM
Default Gateway . . . . . . . . . : fe80::e222:3ff:fe60:95b5%25
192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 278946705
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-E1-D1-24-B8-97-5A-CE-5D-0D
DNS Servers . . . . . . . . . . . : 2602:306:3627:e750::1
192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:3085:3764:9c9d:818a(Preferred)
Link-local IPv6 Address . . . . . : fe80::3085:3764:9c9d:818a%13(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 150994944
NetBIOS over Tcpip. . . . . . . . : Disabled
My PING is 27 M/S
My Downloading is ~12 Mbs
My Uploading is ~ 1.45 Mbs
  • Someone please help me.... im honestly getting frustrated about this. Now the internet ping SUCKs.
    • michaelkenward's avatar
      michaelkenward
      Do you have the correct WIndows drivers for your wifi devices?
      • NeedHelpBCimDum's avatar
        NeedHelpBCimDum
        Maybe !?!?!?!?!?! i used the driver that i downloaded from Netgear A6200 adapter driver
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi NeedHelpBCimDum,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
