Tarquos
Dec 27, 2017Aspirant
Netgear Genie Attempting Connections with Auto-connections Already Selected
Pretty much the title. On boot-up Netgear Genie attempts to run the push n connect service, despite me already having automatically connect to wireless networks. When told to cancel, the genie re-ini...
michaelkenward
Dec 28, 2017Guru - Experienced User
Tarquos wrote:
Pretty much the title. On boot-up Netgear Genie attempts to run the push n connect service...
Is that the Netgear desktop genie? Do you mean Windows boot?
If so, why not just disable the launch of the genie?
- TarquosDec 29, 2017Aspirant
Genie is currently disabled on startup. Hence my confusion. At least, via task manager it is, and via the programmes properties, there doesnt appear to be any option to change it.
- michaelkenwardDec 29, 2017Guru - Experienced User
What do you mean by " Auto-connections Already Selected"?
Where is it already selected?
What is connecting to what?
These don't seem like familiar bits of the desktop genie.
A screen shot can be a great help.
