DukeNukeum's avatar
DukeNukeum
Netgear Genie keeps poping up
Yesterday my Netgear Genie Auto Updated the software on my computer which is a Windows Vista Gateway Desktop and ever since it was updated  whenever I reboot my computer the Netgear Genie keeps popping up and asking me which wifi connection I want to select despite the fact that I already have one selected automatically. How to I set it to stop popping up without clicking on the icon first which I am not doing since I don't need to select Network. Please let me know how to stop the annoying pop up. Thank for taking the time to read this everybody.:smileyhappy:
"Come Get Some!" Duke Nukeum
  • JamesGL's avatar
    JamesGL
    Apr 17, 2016
    Hi DukeNukeum,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi DukeNukeum,
    Try to uncheck it on the start up of your computer. Also, if you don't want to use the Genie, you may uninstall it.
    • DukeNukeum's avatar
      DukeNukeum
      Thanks I will try that then. If I have any more problems I'll be sure to post on here again.:smileyhappy:
      • JamesGL's avatar
        JamesGL
        Hi DukeNukeum,
