kairukun93
Oct 26, 2016Aspirant
NETGEAR Genie The NETGEAR A6210 is not found?
Hi, I recently purchased a NETGEAR A6210 AC1200 High Gain Wireless USB Adapter, the main issue is that when I tried to install NETGEAR Software "Genie" which it suppose to like update the USB WiFi Ad...
- Feb 04, 2017
I had the same problem. I have only USB 2.0 but ended up installing the full .exe installer with Genie and could not get past this error until I just went back to the unzipped file and installed the Standalone file and to it to reinstall. I then plugged the device into the usb port and now it recognized the adapter!
kairukun93
Oct 27, 2016Aspirant
I'm not saying it's a bad product, it's just that the OS Windows 10 has a lot of compatibility issues with the most USB Wi-Fi Product, it's just that Windows 10 hates USB WI-Fi adapaters. Even in Windows 8/8.1 had the issues with some of USB Wi-Fi Adapter. SO NETGEAR, PLEASE FIX THIS PROBLEM, also I notice the network mode is only going 802.11n instead of AC, so don't try to tell us that it is running at 802.11ac, that's false advertisement, and it can lead to misconceptions.
