kairukun93
Oct 26, 2016Aspirant
NETGEAR Genie The NETGEAR A6210 is not found?
Hi, I recently purchased a NETGEAR A6210 AC1200 High Gain Wireless USB Adapter, the main issue is that when I tried to install NETGEAR Software "Genie" which it suppose to like update the USB WiFi Ad...
- Feb 04, 2017
I had the same problem. I have only USB 2.0 but ended up installing the full .exe installer with Genie and could not get past this error until I just went back to the unzipped file and installed the Standalone file and to it to reinstall. I then plugged the device into the usb port and now it recognized the adapter!
km2783
Nov 09, 2016Aspirant
Go to Device Manager, then Network adapters, right click 802.11ac wireless card and select properties, click the driver tab, and finally "roll back driver."
This worked for me, even if Windows says I'm connected to Ethernet now on the task bar. At least I have internet. And no, this computer has never been wired.
