kairukun93
Oct 26, 2016Aspirant
NETGEAR Genie The NETGEAR A6210 is not found?
Hi, I recently purchased a NETGEAR A6210 AC1200 High Gain Wireless USB Adapter, the main issue is that when I tried to install NETGEAR Software "Genie" which it suppose to like update the USB WiFi Ad...
- Feb 04, 2017
I had the same problem. I have only USB 2.0 but ended up installing the full .exe installer with Genie and could not get past this error until I just went back to the unzipped file and installed the Standalone file and to it to reinstall. I then plugged the device into the usb port and now it recognized the adapter!
km2783
Nov 09, 2016Aspirant
Nothing else worked. No amount of trying to restart, uninstall .35 and reinstall .34 did anything. But that did. I'm using the connection right now.
