kairukun93
Oct 26, 2016Aspirant
NETGEAR Genie The NETGEAR A6210 is not found?
Hi, I recently purchased a NETGEAR A6210 AC1200 High Gain Wireless USB Adapter, the main issue is that when I tried to install NETGEAR Software "Genie" which it suppose to like update the USB WiFi Ad...
- Feb 04, 2017
I had the same problem. I have only USB 2.0 but ended up installing the full .exe installer with Genie and could not get past this error until I just went back to the unzipped file and installed the Standalone file and to it to reinstall. I then plugged the device into the usb port and now it recognized the adapter!
WAS_1
Dec 08, 2016Aspirant
Me too. The adaptor works ok, but the A6210 Genie won't display on the W10 Pro Desktop - it just flashes an outline screen and then disappears. The Netgear Genie works ok.
Andrew
formatteddad
Dec 08, 2016Initiate
I then went to here: http://www.netgear.co.uk/home/discover/apps/genie.aspx?cid=wmt_netgear_organic and downloaded the genie software independently of the A6210 software and installed it.
- WAS_1Dec 08, 2016Aspirant
That is the Netgear Genie (which works ok) NOT the A6210 Genie - which is different and has stopped working with the latest W10 updates.
Andrew
