MRMRH
Dec 18, 2017Follower
Netgear Genie unable to find adapter
My adapter worked fine until today, when I installed wrong drivers for alot of my hardware. The adapter stopped connecting to my WiFi, telling me that my connection is limited (Usually it shows the d...
michaelkenward
Dec 19, 2017Guru - Experienced User
Is that an error you see in Windows?
Try using the network troubleshooter.
If this is in Windows, remove all the old drivers and reinstall the ones for your wifi device.
If it isn't too late, you can find a Windows restore point and roll your system back to before you installed those wrong drivers.
