gkahn's avatar
gkahn
Follower
Nov 02, 2015
NETGEAR Universal N300 Wi-Fi to Ethernet Adapter (WNCE2001)
Can I connect a Credit Card Processing Machine that requires an Ethernet Port to your
NETGEAR Universal N300 Wi-Fi to Ethernet Adapter (WNCE2001)?
1 Reply
  • If your credit card machine has an Ethernet port, then the WNCE2001 can be used to connect the machine to a Wi-Fi network. The bigger problem may lie with the Wi-Fi router. Some credit card machines require one or more TCP and/or UDP ports to be opened on the router in order to function correctly.
