marcycn's avatar
marcycn
Netgear Wireless-N Dual Band
I have this stick that I use to use years ago on a desktop I had.  I now want to install it on a Dell Desktop and can't figure out how.  I looked for a CD but couldn't find one.  I push the button but it doesn't make the WiFi blue light stay on.  I should have something come up on my screen and ask for a password since I've passworded my modem/router.  Is there directions online I can download?  What do I need to do please? I'm using Windows 10 ver 1709.
  • Found what I needed and it worked.  Thanks.
    • michaelkenward's avatar
      michaelkenward
      For anyone who finds this discussion and its misleading "Solved" tag, the way to solve the problem is to put your model number into this page:
      Support | NETGEAR
      You can then find all the software, including drivers for Windows, and documentation for your hardware.
