nsinha
Apr 09, 2016Aspirant
Netgear WNCE3001 and Tivo Mini
I've connected my WNCE3001 to a tivo mini because i cannot run new networking cables between rooms in my apartment easily or cheaply. I have no problems with live television but cannot consistently c...
- May 04, 2016
Thanks. So confirmed that the Netgear WNCE3001 cannot be used with the current Tivo Mini version.
nsinha
Apr 11, 2016Aspirant
Yes unfortunately.
When i called Tivo, they mentioned that there may be a wireless lag (even if it is a tenth of a second) between the wireless signal and the wired one that may be causing their systems to not be able to work together. I am going to see if connecting the main tivo module wirelessly also instead of via a hard connection will help with the synchronization... since now both modules will essentially be connected to the router wirelessly. I will provide an update after testing this later today.
nsinha
Apr 12, 2016Aspirant
That did not work. It would have been too easy.
So its back to power cycling before i use the tv connected wirelessly if i am not watching live content or the smart apps or unless someone else has a suggestion.
Thanks
- JamesGLApr 25, 2016NETGEAR Employee Retired
Hi nsinha,
I would suggest try to connect both on wired connection since TiVo mentioned that it might be because of the lag on wireless.
- JamesGLMay 02, 2016NETGEAR Employee Retired
Hi nsinha,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- nsinhaMay 04, 2016Aspirant
