nsinha
Apr 09, 2016Aspirant
Netgear WNCE3001 and Tivo Mini
I've connected my WNCE3001 to a tivo mini because i cannot run new networking cables between rooms in my apartment easily or cheaply. I have no problems with live television but cannot consistently c...
- May 04, 2016
Thanks. So confirmed that the Netgear WNCE3001 cannot be used with the current Tivo Mini version.
nsinha
Apr 12, 2016Aspirant
That did not work. It would have been too easy.
So its back to power cycling before i use the tv connected wirelessly if i am not watching live content or the smart apps or unless someone else has a suggestion.
Thanks
JamesGL
Apr 25, 2016NETGEAR Employee Retired
Hi nsinha,
I would suggest try to connect both on wired connection since TiVo mentioned that it might be because of the lag on wireless.
