paladino2's avatar
paladino2
NETGEAR WNDA3100 V2 Stopped working
After 3 years my  NETGEAR WNDA3100 V2 stopped working. One day at my pc when i was downloading a file (1,50GB), the adapter shutted down e never came up, the led not turn on... no signal of life... ç___ç what i can do???
  • JamesGL's avatar
    JamesGL
    Jan 12, 2016
    If same problem with another computer, probably the device is no longer working.
  • Hi paladino2,
    Can you check on device manager under network adapters if you can see the adapter? If not, try to connect it on  a different computer and install it.
    • paladino2's avatar
      paladino2
      Hi JamesGL thanks for your answer. I checked on device manager under network adapters and i can't see nothing about the adapter WNDA3100, i can see just the ethernet card. I tried the same steps under  2 other computer but nothing.... Now i'am thinking that the adapters is burned....Any other ideas JamesGL?
      • JamesGL's avatar
        JamesGL
        Master
