ScottCahill
Jul 09, 2018Aspirant
Network adaptor not found A6100 WiFi adaptor
I cannot figure this out. The crazy thing is, I bought an A6100 WiFi USB adapter and got it to work. I downloaded from the disc, found my network, and was online. My mistake was updating the ...
Lukeqtnz
Jul 16, 2018Aspirant
Scott, have you had any assistance with this at all or managed to resolve the issue?
- ScottCahillJul 16, 2018Aspirant
Good news, I figured it out two days later.
i downloaded the rtwlanu_XP.sys file from:
https://www.pconlife.com/download/otherfile/76637/c6cde470bdea5f41414220e024ce4765/
Enter the captcha and save. My next problem was I was saving the file in C:Windows/sys32/drivers or whatever it is, that doesn’t work. You have to save it right where that error box was looking:
C:program files\netgear\A6100\driver
Maybe a restart and I was golden. It asked if I wanted to update and I said no way, it’s working I’m not messing. Not bad for someone who hates routers and all. Good luck.
