denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
cilonie
Mar 08, 2013Aspirant
Hi denny1514,
Have you tried connecting the wireless adapter on other USB slot?
Is the wireless adapter directly connected to your computer or you are using the Desktop Dock?
What is the operating system of your computer?
You may try to install the wireless adapter to a different computer and check if you will encounter the same problem.
