denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
emondragon
Apr 24, 2013Novice
I too was having the same problem. I discovered when I upgraded from .18 to .26 firmware the problem of not starting up again began. My setup is HP TouchSmart 600 using Windows 7 64bit computer. I uninstalled the .23 firmware and installed again the .18 firmware and problem was solved. I'm afraid to use the firmware updates.
