denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
WirelessWacko
Apr 29, 2013Aspirant
Just did a fresh install with Windows 7 x64 after having some problems with windows 8, Everything seemed to be working fine until the first reboot for drivers.
I have to disable the A6200 through windows, or disconnect the adapter manually. It always seems to work after the first try....
