denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
Mark_K
Jun 15, 2013Tutor
Fuby wrote: I'm having the same issues.. brand new A6200.. latest drivers.. latest bios.. as of this date of posting...and no connect on reboot... unplug it.. plug it in and it connects right up... unfortunate for me..it needs to be able to be connected on bootup.. so it might have to be thrown in the trash or returned..
come on netgear.. you cant be on the cutting edge .. when you can't even make it into a reboot..
Do not use the latest firmware. you have to downgrade to the previous version and then it will connect on boot up.
