denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
bradbort
Sep 12, 2013Aspirant
Its september, and I'm having the same problem. Unfortunately, when I try to download the down level driver, its an empty file. There is no .18 to install. Argh. At least this is a known issue. Apparently, not to netgear tech support though. I called once, and he was clueless, I used their online tech support form, and they were equallly clueless.
