denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
Retired_Member
Oct 15, 2013Check your USB3 port drivers for a update. Some USB3 ports do not work correctly until PC is completely booted up which might be causing the problem. I've seen this on two PC's so far.
I use a wireless key board on a desktop and it will not let me into Bios setup by hitting Delete Key when booting PC using USB3 port. It does however work when using USB2 port. After boot up the usb3 works fine. If I didn't try to enter Bios setup I never would had notice it.
When trying to use a usb3 port to reimage a different PC the image files are not found when drive is in USB3 but are found using USB2. The drive is a USB3 device which does work when PC is running Win 7. The backup image was written to it using WIN 7 backup.
May or may not be the problem but interesting anyway.
