denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
Retired_Member
Oct 15, 2013My mistake Sorry,
I didn't see that info in the entire thread and I assumed (My Bad) that anyone purchasing the A6200 would had expected to connect above 300 which requires a USB3.
System Requirements
Available USB 1.1 or USB 2.0 slot
Data throughput may also be limited by the product’s interface, e.g. to less than 480 Mbps for a USB 2.0 interface.
The product description at best is Quite lame for what it doesn't say.
