denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
bradbort
Oct 16, 2013Aspirant
I've gotten to second or third level tech support on this. They gave me a "debug" driver that seems to solve the problem. Unfortunately, its not released, and does not include the full software implementation. They sent me the latter several times, and it never worked (same issue with having to reset the usb port every reboot). They left me with the impression that they really did not know what issue was causing the problem, and it was just random luck that the "debug driver) worked.
My experience with netgear is that when their stuff works, its absolutely great. The new R7000 router is a case in point. If, however, you need tech support, may the lord have mercy on your soul. I've never had a good experience with them.
