denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
Retired_Member
Oct 17, 2013Regarding Beamforming,
It's my understanding there are two levels of it, if you will of Beamforming and the Netgear client + version is the one which was lost with driver rollback? And the 11Ac version is router based and only requires a 5g AC client?
With the loss 0f Netgears + Driver based client version did you see a drop in signal level?
