denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
IRQ
Nov 29, 2013Aspirant
bradbort wrote: Sounds more like you have some sort of interference. You might want to move your router's channel away from the competition.
This is definitely not my issue, as I'm experiencing exactly the same symptoms as a lot of other people do, which is that upon disconnect, all the wireless networks disappear from the list with the exception of the network you were originally connected to. That network however now only has "limited connectivity" which basically means no network connection whatsoever and you're unable to re-connect to any other network. If you then continue to disable the network adapter, you won't be able to enable it again.
The only known solution so far is to (physically) un-plug the network adapter and plug it in again. Clearly, this is an unacceptable solution for a commercial product.
