denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
davedagearhead
Dec 10, 2013Aspirant
Well I got mine to work but I don't remember what exact setting i had to change to get it to work. I went into the adapter properties (advanced tab) and changed a few settings and it's been stable the past 6 reboots whereas before I would have to unplug and plug mine back in. here are my settings as they appear on the list:
auto
disabled
loose 11h
auto
auto
higher performance
disabled
none
11a/b/g20/40mhz
enabled
disabled
auto short/long
disabled
none
disabled
2346
auto
802.11a/b/g performance
not present
disabled
disabled
100%
priority and vlan disabled
best rate
best rate
auto
optimize bandwidth
2347
auto
auto
11(20mhz)
disabled
I think I changed the Bluetooth, disconnect upon wired connect, minimum power consumption, roaming decision, and xpress.
Good luck folks! Hope for some these settings work for some of you.
btw I'm on a windows 7 64b.
auto
disabled
loose 11h
auto
auto
higher performance
disabled
none
11a/b/g20/40mhz
enabled
disabled
auto short/long
disabled
none
disabled
2346
auto
not present
disabled
disabled
100%
best rate
best rate
auto
optimize bandwidth
2347
auto
auto
11(20mhz)
disabled
