denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
Jene
Dec 13, 2013Aspirant
I've had this same problem - won't connect on startup/restart. I submitted the problem to Netgear support and they provided the solution.. It seems that the A6200 adapter's power-saving mode has been interfering with the WiFi connection. They suggested I disable this feature, and that has solved the problem. This is described in the support article at:
http://kb.netgear.com/app/answers/detail/a_id/23352/~/a6200-or-wnda3100v2-wireless-adapter-intermittently-disconnects
My thanks to Netgear Support. They were very helpful.
