denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
noboundaries
Sep 20, 2014Guide
I have a windows 8.1 x 64, and running the beta 1.0.0.35 and seems to be good. No drop outs,, getting annoying pop up saying its connected every half hour, but it is connected and going ok. I had problems dropping etc, till I went to the beta 1.0.0.35, give it a go ps good speed too 702mbps, , Cheers
