denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
markburgesser
Nov 14, 2014Aspirant
Hi,
New guy here. I was able to fix my A6200 easily with a setting change in windows. I haven't read all of the threads and comments, so maybe it's old news. I spent a long time with Netgear support, but gave up and kept looking. This worked and no problems since. Go into the properties of the adapter, click advanced, and disable the Minimum Power Consumption option. I'm pretty sure that was the fix. Sorry, memory isn't too good. I had the same problem with connecting on boot and wakeup. I'm looking forward to the results. I have never posted before.
