denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
rjbur
Dec 04, 2014Tutor
I have been having the same issue ever since day one that I purchased the unit.
I have been doing the same "workaround" of unplugging and re-plugging it it to make it work.
I just downloaded and installed "setup-V1.0.0.26-win81_signed" the 26-1 version for Windows 8.1. First uninstalled and the installed this one etc...
I "Shutdown" the computer and restated it. It did NOT auto connect to my network as it should have. It did say I had networks available so I choose mine again and at first it reported a problem, but then it connected.
I will now try another shutdown/restart sequence.
Rich
Rich
