denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
rjbur
Dec 04, 2014Tutor
OK after second restart of the system, the same thing with 26-1 version happened.
It did NOT auto connect to the network.
I clicked on the icon and once again had to choose my network and YES there is a check in the box to Auto Connect....
It went through the connection process and then it reported that it had a connection issue and could not connect.... HOWEVER IT DID. When I closed the pop up WIn 8.1 side bar it was indeed connected so a FALSE failure to connect was reported.
I did NOT have to unplug and re-plug unit in.
I guess my new work around is that I have to manually connect to the network using the popup of available connections....
Rich
Rich
