denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
big_j_ny
Dec 11, 2014Aspirant
It happened to me recently after I did a Windows update to my PC.
After I added the new system updates to my Windows 7 64-bit home premium OS, my A6200 did not want to connect to any available network. It could see the network, but it was not able to connect to it at all.
I had to reinstall the drivers in order to make it work, but then it recently started happening again this morning UNTIL I unplugged and re-plugged my A6200 back in.
I hoped when I bought this thing 3 months ago that I wouldn't be running into the similar connection issues as many others have experienced with the A6200, but sure enough it has finally happened to me too.
