denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
jopami
May 15, 2015Aspirant
Cant believe NetGear still hasnt fixed this problem, this is my second one and the disabling the advanced power feature in the device manager didnt work for me. Still randomly cuts out although it usually happens while I am downloading large files, which is frequently, but it happens like every 5 minutes, I envy those of you who are able to get in an hour of gaming.
As much as I love my router, I am never buying Netgear again. Not worth the trouble, I cant believe they are allowing these to be on the market.
