denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
NomakeWan
May 29, 2015Aspirant
Is anyone using the Mediatek driver by itself? Ever since removing all the Netgear software and using the driver supplied by the company that made the chip Netgear is using, I have had zero issues with my A6210. It reconnects to my 5GHz network on every reboot and doesn't spontaneously disconnect.
