denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
kwolf
Jul 06, 2015Guide
minions08 wrote: For new drivers you can it on support site.
http://support.netgear.com/product/A6200
That's actually incorrect, because the 1.0.0.35 drivers are not listed there. The Netgear FTP link for those drivers is broken. Netgear support blew me off instead of giving me the driver (or whatever is newer than it).
The driver file inside of the "official" 1.0.0.26-1 driver is ~2 years old and does not fix the non-connection on restart problem.
