denny1514
Feb 21, 2013Follower
New A6200 doesn't connect after restart.
Hi Guys, Having issue with A6200 not connecting after restart, i have to take it out and plug it back up then it reads it. Is this normal or is there a fix for this? thanks in advance
TheGuy
May 05, 2013Initiate
This may not be the answer some of you want but a fix for this is to create a batch file and run it at start up using task scheduler at logon.
This batch file disables and reanables the adapter after 5 seconds. The ping command acts as a pause. You may need a longer pause.
I changed my adapter name so you'll need to get the name off of you system and make the appropriate changes.
Hope This Helps!
@echo on
netsh interface set interface "NETGEAR A6200 WiFi Adapter #2" DISABLED
ping localhost -n 6 > nul
netsh interface set interface "NETGEAR A6200 WiFi Adapter #2" ENABLED
Hope This Helps!
BurtLight
Oct 28, 2015Aspirant
I gave up. After a few hours on the phone with tech support, and a few hours trying various schemes to make this adapter work, it just was not worth it. I returned it to Amazon.
