Alex2210's avatar
Alex2210
Nighthawk AC1900 Model A7000 connection speeds slow with random ping spikes
Purchased the A7000 so that my desktop could connect over wifi to my router. The router I have is the XR500 and my modem that the router connects to puts out about 120 mb/s. The two story house I live in is only about 1500 sq feet and the router is downstairs while the computer with the usb wifi adapter is upstairs. On both devices the firmware is up to date and the usb adapter is connected to a usb 3.0 slot. The problem I am having is that my desktop is only getting download speeds of about 100-150 kb/s. I have tried disabling the Auto Configuration logic in windows command and it does help some times but when I do that my network no longer shows up even though the device is still connected. Also if I disable that function I have to re-enable it to reconnect to my wi-fi if the desktop is turned off or the connection is lost.
  • By the way the desktop is running
    Windows 10
    Version 1803
    OS Build 17134.345
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi Alex2210
      Welcome to NETGEAR Community!
      Have you tried to uninstall and re-install the adapter? Are we just having wireless speed issue with the Win10 Desktop? Or does it also affect other wireless devices?
      Blanca
      Community Team
      • Blanca_O's avatar
        Blanca_O
        Hi Alex2210
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
        Blanca
        Community Team
