pdes
Oct 12, 2013Guide
No speed improvement with A6200
I have set up my A6200 with Windows 8 and have connectivity with my D6300 on the 5g channel. The Genie window says I have around a 300mb connection but when testing a download from my NAS to my PC, I...
Retired_Member
Oct 15, 2013Taken from product overview sheet, "Data throughput may also be limited by the product’s interface, e.g. to less than 480 Mbps for a USB 2.0 interface" 300 is less than 480? USB3 ports are Blue, what color is yours?
The cause of the dismal transfer rate of 4mb between PC & NAS could be something entirely different other than a WIFI problem.
Need to look at ALL Hardware specs like HARD DRIVES and motherboards on both devices. You can bet the wireless transfer speed will never be hire than wired. Unless wired is outdated or broken.
Your initial post said you were looking for an improvement in transfer speed but you never said what you had to begin with.
