pdes
Oct 12, 2013Guide
No speed improvement with A6200
I have set up my A6200 with Windows 8 and have connectivity with my D6300 on the 5g channel. The Genie window says I have around a 300mb connection but when testing a download from my NAS to my PC, I...
pdes
Oct 15, 2013Guide
searay wrote: Taken from product overview sheet, "Data throughput may also be limited by the product’s interface, e.g. to less than 480 Mbps for a USB 2.0 interface" 300 is less than 480? USB3 ports are Blue, what color is yours?
Your initial post said you were looking for an improvement in transfer speed but you never said what you had to begin with.
I don't see any colour on the USB port - only that it connects by a slightly different plug. the standard USB also fits.
The PC reports a connection of 280ish mb but the throughput is around 4m and this was what I started with. Given that I could be mixing bits and bytes, this would still only mean a throughput of around 34k.
I have a QNAP nas that is fully up to date and connected with Ethernet to the router so don't think there are any weaknesses there. I have still to try the direct connection to the PC so maybe there are issues with the wireless setup.
Cheers
